Re: Water leaking from showers cold water turn-on valve
Posted by e-plumber on January 17, 2004 at 18:34:27:
In response to Re: Water leaking from showers cold water turn-on valve
: Is it possible to just replace the showers turn-on handle valve without having to get into the wall? Lately, when the water is turned of, it leaks from the faucet as if it wasn't turned off all the way. Reply: Replacing only the handle will not correct your problem, the faucet most likely needs to be repaired by replacing the internal parts. It can be done without damaging the wall. Good Luck. e-plumber
Replies to this post
There are none. |
