| Posted by e-plumber on January 17, 2004 at 18:19:47: | |
| In response to Re: No Water from Delta Scald Guard Faucet | |
: I have a 10 year old Delta Scald Guard shower faucet that has worked well in past; however, we don't use the bathroom much. Some times when you move the lever CCW from 'off' no water comes out, and sometimes a trickle comes out. When flow is coming, the closer you move the lever to the Hot side the slower the flow of water becomes. : I took the 'cartridge' out, and I can get high flow from the cold port if I block the hot, but no flow from the hot port if I block the cold port. : Any suggestions? Reply: |
| There are none. |
