| Posted by Terry Evans on January 17, 2004 at 17:34:05: | |
I have a 10 year old Delta Scald Guard shower faucet that has worked well in past; however, we don't use the bathroom much. Some times when you move the lever CCW from 'off' no water comes out, and sometimes a trickle comes out. When flow is coming, the closer you move the lever to the Hot side the slower the flow of water becomes. I took the 'cartridge' out, and I can get high flow from the cold port if I block the hot, but no flow from the hot port if I block the cold port. Any suggestions? |
