Re: Champion toilet intermittent refilling
Posted by Gary Swart on January 17, 2004 at 14:51:08:
In response to Re: Champion toilet intermittent refilling
Sounds like the flapper is not seating. This allows the water level in the tank to gradually drop. As the water level drops, the float valve opens to refill the tank. Since the toilet was just installed, you may just need to adjust the flapper to get it to drop squarely into the hole. If that fails to correct the problem, a couple of buck for a new flapper will do it.
Replies to this post
There are none. |
