| Posted by Peter on January 16, 2004 at 08:44:27: | |
| In response to Re: Basement Shower Stall | |
Forgive me if I'm reading your request incorrectly. How can the room be too small? What are its dimensions? If you can't fit a fixture, how can you fit a stall? As far as plumbing from the front, normally, you rough in the plumbing and then install the shower. You don't put the stall in first. : Need some help finding info on a basement shower stall. The entire basement is remodeled with the exception of the bathroom, and I would like a nice bathroom. Problem is the basement bath is block walls on all 4 sides. Also the room is too small for building fir walls on the inside. Therefore all water lines come from the ceiling and drop down. Most corner shower stalls I have found are plumbed from behind. Does anyone know of a corner shower that can be installed and then plumbed from the front through some type of access panel? Or one that comes preplubed with extension hoses that conect up above the stall? : Thanks in advance, : Matthew
