Re: Compression fitting problems
Posted by Deb on January 15, 2004 at 19:49:05:
In response to Re: Compression fitting problems
: I am hard connecting a toilet with 1/2 inch flexible chrome pipe. The fitting on the stop is a compression fitting. This is my second try (the first I gorrillaed the nut until I broke it.) I keep getting water seeping through between the pipe and the sleeve. What could be causing this continual problem with such a simple device. I am at my wits end... Go to the local home improvement store and buy a stainless steel flexible closet supply line. Deb The Pipewench
