Re: sewage smell coming from shower drain
Posted by e-plumber on January 14, 2004 at 21:22:58:
In response to Re: sewage smell coming from shower drain
: A very strong sewage smell comes up from our shower drain after taking a shower. A plumber was recently out to the house and found no reason for this to be happening. He said we may have to pay quite a bit of money to run a camera down through the pipe to see if there is a possible crack.
: Have you ever heard of this problem? If so, any ideas on what may be causing it?
: Thanks.
A crack in the shower drain line would not cause odor while or after showering if the drain trap is holding water while you shower and when you're finished. The water seal in the drain trap is what prevents odors from being emitted from the drain.
Did this problem just start or has it been ongoing? The odor may be from the water itself.
Good Luck. e-plumber
Replies to this post
