| Posted by soxman on January 14, 2004 at 20:17:38: | |
| In response to Re: Hard to Reach Leaking Joint | |
: Your plan will work, but don't use a compression fitting in the wall. You do need to take down or cut 2" X 4"'s unless absolutely necessary, don't create any more work than you need to. : Good Luck. e-plumber E-plumber or anybody- Is using PVC acceptable? And if so, how would you go about doing this if you were replacing just that supply line from the valve to the elbow up top?
