| Posted by hj on January 14, 2004 at 17:44:26: | |
| In response to Re: water pipe leak | |
If you think it is mysterious and you are there where it is, think of how much more difficult it is for us not being able to see the water heater or the leak. It may be a leak from the temperature/pressure relief valve while the water is heating, but we would be guessing as to the cause. If you cannot determine the problem, call a plumber. : help we have mysterious leak in our home it seems when our gas water is on which is located in laundry room our hallway outside of the laundry room becomes saturated with water we ahve been unable to find out the problem also the hot water will not turn off in the bathtub facet unless the water heater is shut off
| There are none. |
