Re: Hot Water Radiant Heat Registers
Posted by hj on January 13, 2004 at 22:31:57:
In response to Re: Hot Water Radiant Heat Registers
Whaat makes you think that covering the radiators will make the system more economical? It may have just the opposite effect if you do too good a job of covering them and the heat has to run longer to heat the rooms.
: I have hot water heat in my old house and wish to make it more economical and I was hoping that you can advise me in regards to covering the rads. Do you know where I can find plans to build my own and what kind of heat conductor should I use when I do so. Any information in regards to this type of heat would be very helpful.
: Thank-you for your time.
: Doug Bennett
: dougontario@hotmail.com
Replies to this post
There are none.
