: I recently had woodford 22 faucet installed in my garage for use of warmer water when washing cars. Problem is, there is not enough water pressure for a good spray. Are there any adjustments that i can do to the faucet to get better water pressure? Is there anything obstructing the pressure in the faucet? Reply: If the rest of the water pressure in the house is adequate, there is no reason why the newly installed faucet should not be the same unless there is a restriction in the line or a valve is partially closed. Good Luck. e-plumber
