| Posted by hccarpenter on January 13, 2004 at 21:34:30: | |
| In response to Re: low water pressure | |
What does it means if you have 50# in the static mode and 10# in the dynamic mode?
: Buy an inexpensive pressure gauge; check the house pressure both in static mode ( no water running) and in dynaminc mode (one or more faucets running). This will help you narrow down the problem. : If you are a novice, replacing the regulator is not a good first project to tackle. Call in a profesional.
| There are none. |
