| Posted by Gary Swart on January 13, 2004 at 17:23:44: | |
| In response to Re: Sewer Line Clogs Often | |
You are certainly correct about the vent not being code, but that isn't causing your clogging problem. Either the clog isn't being totally removed or there is something in the pipe that is catching debris. From the description of your system, I'd suggest you have a plumber evaluate and repair your drain/vent system. |
| There are none. |
