Re: Faulty pressure regulator on galvanized supply line
Posted by Gary Swart on January 13, 2004 at 17:19:15:
In response to Re: Faulty pressure regulator on galvanized supply line
Simply cut one of the 10" pieces of pipe and disconnect them. You will rejoin the pipes by using a union and 2 nipples, short pieces of pipe, of appropriate lengths to fit back into the space where the 10" section was removed. You may be able to find ready made nipples of the right length, or you may need to have a piece cut and threaded.
Replies to this post
There are none. |
