Re: Toto G-max and water pressure
Posted by So. Cal. Plumber on January 13, 2004 at 00:57:36:
In response to Re: Toto G-max and water pressure
: Does the Toto G-max system require a certain water pressure to function correctly? I'm considering a Drake, but the water pressure from my well is not very high-- probably around 35 psi, if I remember right. The G-Max is gravity fed so it doesn't require a certain amount of pressure, it just would take slightly longer to fill the tank is all. It is a very good toilet, you won't be dissapointed.
Replies to this post
There are none. |
