Re: Delta shower/tub valve
Posted by hj on January 12, 2004 at 08:10:31:
In response to Re: Delta shower/tub valve
It should "stick" when it is pushed all the way in. If it does not, tightening it will not do anything to help the problem. It may be a non-Delta part with an extra strong spring.
: Just bought and intalled a new "valve" to divert water from tub to shower for a Delta. Problem is that when you push in the button once you get to a certain point it "should" stick or hold in place allowing the shower to work. It doesn't stick or catch in place so unless you hold it in place the shower doesn't work. I tried tightening the part this evening and still no luck.
: Any insights?
Replies to this post
There are none.
