Re: I need help, no water from faucet or toilet!!
Posted by pw on January 11, 2004 at 10:15:58:
In response to Re: I need help, no water from faucet or toilet!!
Most likely frozen pipes. You may want to track the path of the lines in question to see where they are being exposed to outside temperatures. Some times some simple insulation will resolve the problem. Depending on the situation you may need to add some electircal heat tape, or have the pipes re-routed.
: I have a house with 3.5 bathrooms. Recently the 1/2 bathroom located on the first floor stopped running water. Initially it was only the hot water side, but today the cold water side and the toilet stopped running water. The other 3 bathrooms are in working order though. What can be causing this problem??
: Of note, I recently upgraded my oil burner. Also the temperature is very cold outside .. near 10 degrees Fahrenheit.
: I appreciate any input. Thanks.
Replies to this post
There are none.
