Leak under sink from plug assembly
Posted by Mel on January 10, 2004 at 17:43:03:
My bathroom sink has a plug assembly. We found a leak under the sink and on close inspection water drips out of the drain assembly where the plug lever rod connects to the bottom of the drain plug. I realize that the opening in the drain assembly is not water tight so I guess water is not supposed to get around there, but it does on my sink. I pulled out the drain plug and is appears fairly clean.
Sorry I cannot describe the problem better...h
Replies to this post
There are none.
