| Posted by Ducs on January 10, 2004 at 11:09:03: | |
| In response to Re: Grohe shower valve fix | |
Also, does anyone know how to adjust these units so the water is hotter? When we had the water at 100 degrees it was definitely colder than that. Even the highest setting is barely warm enough. : We have one of those Grohe adjustable temperature showers. I believe this model is called Grohtherm. : Does anyone know what is the right procedure to get the brass piston to retract backwards? : Thank You
| There are none. |
