Re: Chemical Drain Cleaners
Posted by kid on January 09, 2004 at 15:38:50:
In response to Re: Chemical Drain Cleaners
: Hi Terry, : Thanks for being there to help. : Are there any chemical cleaners that really (REALLY) : work well? From 35 years as a homeowner/handyman, I : know that CLOGGED drains usually have to be opened : using plumbers tools - not chemicals. : However, to reduce drain buildups that eventually slow : down & then clog drains, a really effective chemical : cleaner would seem to be helpful. Several years ago I : tried a box store enzymatic liquid which helped, but : it was slow to work & left some thing to be desired. : I have access to several major plumbing supply dealers. : Are there any "professional" or "industrial" grade : products that I should check out? : : Best regards, Dick You all die!!! Go to hell bitches!!!
Replies to this post
There are none. |
