Re: Last joint leaking in water supply
Posted by Gary Swart on January 08, 2004 at 19:07:19:
In response to Re: Last joint leaking in water supply
I going to venture a guess that the water is coming from the cold through the mixer. It seems like heat from the torch draws any water that is nearby. I had a heck of a time putting a new cut off valve on my main water supply line once. It just would not dry up. I ended up with some long strips of cloth that I work in to the line with a stiff wire. Had twine on the cloth to pull it out. Maybe one of the "real" plumbers will respond with more techniques.
Replies to this post
There are none.
