| Posted by Jon on January 08, 2004 at 13:04:16: | |
| In response to Re: moen shower not hot enough | |
If its a Posi Temp control you can buy a rebuild kit for under $10.00 at Lowes or Home Depot.If you call Moen they will send you the part.1-888-45-5830.Jon : I have a single knob moen shower setup. Every once in a while it will put out nice hot water if you turn it up really slow. But if you just turn it on full hot it never gets as hot as I'd like it. I tried playing with the temperature limit ring, but its already set to give you maximum range. All the other faucets in my house put out hot water. Are there any adjustments I can make to fix this?
| There are none. |
