| Posted by Jon on January 08, 2004 at 13:00:35: | |
| In response to Re: Showerhead Drip | |
Mel You can call Kohler and they will send you the correct cartridge..it may even be free if its covered under one of there life time warranties.Their number is 1-800-456-4537 : Hi, : Several questions: : 1- Can I remove the valve stem from the showerhead WITHOUT shutting off the water at the main valve? : Thank you, : Mel
| There are none. |
