| Posted by Deb on January 08, 2004 at 10:32:04: | |
| In response to Re: Kitchen sink | |
: He is doing something wrong, but we cannot tell you what it is. Normally, if the nuts and washers are assembled properly, it does not leak even if they are not super tight. : : My husband has replaced our plumbing under our stainlesss steel double bowl sink two times. Neither time has he gotten a good result. It always leaks somewhere. Need advice. We do not have dishwasher or waste disposer. We used pvc valve. Thanks. I'm confused. Did he redo the water or the drainage? What is the pvc valve you used and where did you use it? |
| There are none. |
