| Posted by hj on January 07, 2004 at 22:13:30: | |
| In response to Re: Showerhead Drip | |
Yes, it is probably a pressure balanced valve and if so, the leak could be, and often is, a crack in the balancing spool, not the washers. And if so you need to replace that piece. : Hi, : Several questions: : 1- Can I remove the valve stem from the showerhead WITHOUT shutting off the water at the main valve? : Thank you, : Mel
| There are none. |
