Re: moen shower not hot enough
Posted by e-plumber on January 07, 2004 at 20:31:48:
In response to Re: moen shower not hot enough
: I have a single knob moen shower setup. Every once in a while it will put out nice hot water if you turn it up really slow. But if you just turn it on full hot it never gets as hot as I'd like it. I tried playing with the temperature limit ring, but its already set to give you maximum range. All the other faucets in my house put out hot water. Are there any adjustments I can make to fix this? Reply: It appears you made the adjustment already and it didn't help. Depending on the model, you may need to replace the internal cartridge. Some Moen faucets also have a balancing spool inside the faucet body that may need to be replaced to correct an inadequate HW problem. Good Luck. e-plumber
