Re: Tankless Water Heaters
Posted by double diamond construction inc. on January 06, 2004 at 20:44:21:
In response to Re: Tankless Water Heaters
we purchased three envirotec tankless with really bad luck. one heater leaked so we replaced it with one of the others. we were told by envirotec they had had this problem with a manufacturing fault but thopught it was fixed. we returned the unit for a refund. then they said it was a loose nut. our plumber said it was comming from the element which matched the first story they had given us. then we installed the second one in a large bathroom. no hot water, just warm. tried to turn the heater to what the book said (140o) only went to 134. called to be told it won't go to 140, the reason they gave us was they did not want anyone to get burned. then they said they could replace it with one that would work. so far almost a year and no refund and cold showers. you might want to go with the other company.. sure wish we would have. now we have two very unhappy customers and are without the money and the heater and the cost of a plumber three times for the time it should have been once.
Replies to this post
There are none. |
