Re: How do I remove the Anode Rod and where is it located?
Posted by Deb on January 06, 2004 at 10:39:50:
In response to Re: How do I remove the Anode Rod and where is it located?
: I have an electric water heater. I only have a hot and cold water intake and outgoing pipes on the top.. nothing else. Where is the anode rod located? Mine is a 50 gal. tank and have been told that it is in the top, but where? and how do I remove it?? I took the water lines off, but see nothing inside the connectors that come out. I would appreciate any help. Thanks
Why do you want to remove your anode rod?
Deb
The Pipewench
Replies to this post
There are none.
