| Posted by Randy on January 05, 2004 at 19:41:57: | |
| In response to Re: Shower Valve Location | |
: Moen makes an extended stop tube and handle extension for that problem. Since this is a shower it probably does not have a diverter stem in it. : : I replaced a leaking cultured marble stand-up shower with a 3 piece remodeler from Aqua-Glass. I want to use the existing Moen single divertor valve but the stem is not long enough to install the handle, fittings etc. : : Is there anyway I can extend the valve by about 1" so I can install shower handle and trim ring properly?? : : If not, do different fixtures have different lengths of valve stems??? : : Thansk???
| There are none. |
