Re: Want to move cleanout
Posted by e-plumber on January 05, 2004 at 14:24:04:
In response to Re: Want to move cleanout
: I want to move the cleanout in basement to a new location. It will be much more accessible and I will not need to install an access door in the wall. I've got a bitmap below. Do you think either A of B would work? Thanks for the insight
In theory it would work but the additional 60+ feet of drain piping, not counting the distance to the other clean-out fitting outside the house could make cleaning the line more difficult to negotiate the snake cable past the extra fittings and piping. Most codes require that there is a clean-out fitting before the main drain exits the house, at the foundation wall.
Good Luck. e-plumber
Replies to this post
There are none.
