| Posted by e-plumber on January 05, 2004 at 14:13:37: | |
| In response to Re: Bleeding Hot Water Heat System | |
: I recently purchased a home built in the mid 1930's. It has a new (5 year old Boiler) and of course a hot water heating system. The house is a two story house with a basement. The first and second stories are on one zone with the basement on a second. In every room there is a unit that has fins like a baseboard system only is behind a 2' by 3' vented cover. Each "heat register" has a shutoff and a bleeder valve. After bleeding the system twice, we have one room that does not always get hot. : Should you start at the top or bottom of your system when bleeding each register?? Reply: |
