Re: water pressure
Posted by e-plumber on January 05, 2004 at 09:06:01:
In response to Re: water pressure
: i was using my bathroom taps then i heard the pipes rattle and now i have little water pressure. i have pressure every where else. what could be the problem. thanks
Reply:
There could be something loose inside of the faucet blocking the flow.
1.) Make sure the shut off valves under the basin are fully opened.
2.) You may need to disassemble the faucet stem(s) and inspect it internally for debris.
Good Luck. e-plumber
Replies to this post
There are none.
