Re: Bathroom shower remodel
Posted by Steve on January 05, 2004 at 01:11:50:
In response to Re: Bathroom shower remodel
If you're taking out a corner stall then the studs will be exposed when you remove it. Just drill & run your water lines around the corner through the studs. : Currently have a corner shower unit with shower head coming off one wall and faucet off same. Want to remove and install a full size shower, and have shower head come off opposing wall. Problem is this wall backs up to the guest bath. Does this entire wall need to come out or can I cut through drywall to install T connectors for each shower head and faucets in each bathroom? If so, how challenging is this?
