Re: water pressure problem
Posted by steve the plumber on January 04, 2004 at 17:51:23:
In response to Re: water pressure problem
1)Did you adjust your PRV? 2)Most T&P's on water heaters blow at 125psi. : I have replaced my water pressure reducing valve,but mt pressure guage keeps going up to around 120 after hot water use.I have also noticed that my pressure release valve on my hot water heater releases when the pressure gets up there.I have also put in an expansion tank with no change.Could my problem possibly be my pressure release valve needs to be replaced?Any info would be appreciated.
Replies to this post
There are none. |
