| Posted by alv on January 04, 2004 at 00:15:50: | |
| In response to Re: Volume and pressure problem with shower | |
Thanks again hj...I will give them a call. : Andre ia not a common faucets in most areas, but there should be a specialty plumbing supply source that deals in the "off brand" faucets where you can get a service diagram for it. Or contact Andre directly at 1-800-756-2284. : : Thanks hj...is this something I could do myself? Is there a place where I can find repair or parts info on this particular valve? : : : Calling a plumber to test the valve and possibly free up the balancing unit will be a lot cheaper than replacing a wall. : : : : I have a two handle (one for volume and one for temp-on/off) Andre shower valve model 2015-204-IP-SN that has very little volume or pressure. When on the cold side ti is much better but the volume handle does nothing. : : : : Any help on how to repair this would be much appreciated...my wife is about to rip open the wall!!!
| There are none. |
