| Posted by Tom Holmes on January 03, 2004 at 18:15:25: | |
Hi Terry, Our hot water bath tap does not allow water to go into the main "center" faucet. The cold water works fine. I traded the cold water tap with the hot water tap and still the hot water will not come out the center. Yet there is water behind since if I take the entire tap out water comes out. I blew air into the cold water line and noticed it freely came through but the hot water tap seemed to be blocked. I tried the ol' wire method to see if there is anything blocking it but I came up stumped. Do I have to replace the entire "tree"? Yours most frustrated,...because I had to take tile out to work on this (very messy tub now)and I do not look forward to the task of replacing it. These are older copper pipes with no threads and I never done this before. Tom
