Re: Pressure relief valve
Posted by JF on January 02, 2004 at 13:59:33:
In response to Re: Pressure relief valve
As long as you turn off the cold water supply and turn off all electricity and/or gas to the tank, you can't really do much damage to yourself or the appliance. You will need some tools, though. Here is the address of a web site that should help: http://www.factsfacts.com/MyHomeRepair/PressureRelief.htm
JF
: Would it be possible to get step by step instructions on replacing the pressure relief valve on my hot water tank. It is dripping steadily. It needs to be a simple blow by blow as I am a novice....or should i be hiring a plumber...thought it might be an easy fix..thanks kindly...Jackson
Replies to this post
