Re: well pump system
Posted by Hube on January 02, 2004 at 10:05:25:
In response to Re: well pump system
: My well pump will fill the tank when the I first turn the breaker on; but when the tank gets low on water, the pump doesn't kick back on. Is this the regulator?
It can be a pessure adjustment is needed at the pressure switch. Also, is this a bladder type tank (air valve on top )Post back with info and we will advise a remedy to the problem. Hube
Replies to this post
There are none.
