| Posted by hhj on December 31, 2003 at 21:38:29: | |
| In response to Re: Offset Flanges | |
You cannot use a PVC/ABS offset collar since you will have no way to secure it to the pipe. Cast iron offset collars, there are two different kinds each has its own "difficulties" and you probably need a plumber to install it. You would be better off getting a 14" toilet which would then sit the norma 1" from the wall. : I completeing a 3/4 bath and the new toilet sits three inches from the new wall. Now, can I use a PVC offset flange on a cast iron soil pipe or do I have to hire a professional the come in and put on a cast iron flange? Please help.
| There are none. |
