: We've done major renovations to our basement, including having the supporting wall taken out and replaced with a steele beam. The problem now is that where they dug out the existing posted..its leaking and we've already layed carpet. We've tried the waterproof floor paint but its not working. Help!? Reply: You could be on a high water table or the table shifted causing your problem. Attempting to patch that area may cause the water to surface somewhere else in the basement. You may need a sump pump installed or a water proofing company to inspect. Good Luck & Happy New Year. e-plumber
