Just to clarify -- Best way to Install bathtub spout
[ Follow Ups ] [ Post Followup ] [ Terry's WWWBoard ] [ FAQ ]
Posted by MarkDIY on December 29, 2003 at 09:59:54:
In Reply to: Re: Best way to Install bathtub spout posted by hj on December 29, 2003 at 09:25:42:
Just wanted to clarify that instead of the copper elbow and the stubout line soldered to it -- I could remove that and solder on a brass female elbow fitting. Then, I would solder a male brass nipple onto the end of a 8" copper pipe and screw that into the elbow fitting (for the stubout line). For attaching the spout, I would solder on a male brass nipple at the other end of the same copper stubout line as well. Correct?
: The best way, long term is to use a female adapter elbow and a brass nipple, not galvanized. That way in the future you can change the dimension if you have to replace the spout and cannot find an exact duplicate.
: : I've installed a new bathtub and have stubbed out a 1/2" copper line from an elbow where the bathtub spout will be. I will then cut it off and solder on a male threaded connection and screw the spout on. Is there a better way than this? Also, what is the best way to measure where I need to cut the stubout so the spout is not too short or too far from the wall?
: : I thought about putting in a brass elbow and then screwing in a piece of galvanized pipe. Is that a better route to take than copper? The copper seemed easier and I had all the fittings.
Follow Ups:
Post a Followup
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
