| Posted by hj on December 29, 2003 at 09:41:26: | |
| In response to Re: Leak, toilet or flange? | |
That crack, if that is what it is, should be a surface one, but it should also be withing the perimeter of the wax ring, so even if it were leaking, the water would still go down the drain. IF you have a leak beneath the toilet, it is somewhere else. : This is a picture of what I think might be causing a leak in my toilet. I am not positive if the crack goes all the way through though. Do you have any thoughts on it. It is a Kohler San Rafael low boy one piece 3.5 GPF : The other 2 pics are of the flange. From what I have read it appears to mounted correctly... level with, or slightly above the floor surface. : If I have to get a new toilet, I will, but I don't want to if my is fine. : I feel pretty confident that I seated the toilet correctly. My next thought is to get a thicker wax ring with the foam base?
| There are none. |
