| Posted by hj on December 29, 2003 at 09:25:42: | |
| In response to Re: Best way to Install bathtub spout | |
The best way, long term is to use a female adapter elbow and a brass nipple, not galvanized. That way in the future you can change the dimension if you have to replace the spout and cannot find an exact duplicate. : I've installed a new bathtub and have stubbed out a 1/2" copper line from an elbow where the bathtub spout will be. I will then cut it off and solder on a male threaded connection and screw the spout on. Is there a better way than this? Also, what is the best way to measure where I need to cut the stubout so the spout is not too short or too far from the wall? : I thought about putting in a brass elbow and then screwing in a piece of galvanized pipe. Is that a better route to take than copper? The copper seemed easier and I had all the fittings.
