Re: Installing a thermostat
Posted by e-plumber on December 29, 2003 at 07:28:42:
In response to Re: Installing a thermostat
: How far does a thermostat need to be from a floor to ceiling cabinet to insure proper airflow? There is a door to the other side of the thermostat and the space to the front is unobstructed. Reply: This question sounds familiar... The thermostat needs to be located in an area where it will not pick up any cold drafts from the door opening and closing and should not be mounted on an exterior wall. The thermostat height from the floor is usually about 5'. Good Luck & Happy New Year. e-plumber
Replies to this post
There are none. |
