| Posted by Chris on December 29, 2003 at 01:39:29: | |
| In response to Re: Laundry Drain | |
: Thanks for the advise. I can install a p-trap and a vent, but there is no way I can direct the drain to a first floor outlet. There is no space under the garage floor. I have to drain into the basement thru the wall plate : John Z Why not connect to an existing drain line in the basement instead of doing the indirect thing? If you can trap it and vent it, there's no downside to breaking into an existing line, unless it's cast iron... in that case, of course, it's something of a pain, but it *can* be done. |
| There are none. |
