| Posted by Buddy Phillips on December 28, 2003 at 16:05:47: | |
| In response to Re: Food Disposal | |
: : Should a food disposal be connected to a copper drain pipe? I will be using plastic to run from the unit to the wall where the copper pipe starts. A relative says that it causes the copper to deteriorate causing the pipe to leak in the wall. Is this true? : Reply:
| There are none. |
