: : : : I am moving a washer from the basement to the first floor. I ran a 1 1/2" drain approx 30' to the existing utility tub in the basement. I installed no trap or vent because i am going into a utility tub. Before i close up the wall, is 1 1/2" large enough? : : : : : : NO. : : : Washers require a 2" drainage line. : : : Indirect waste should be on the same floor. : : : You still need a p-trap and vent. : : : This is a really bad install and I would rethink the whole thing before I closed up the wall. : : : If you decide to go with this, check your homeowner's insurance to see if it covers flooding caused by incorrect, unpermitted, uninspected plumbing. : : : Deb : : : The Pipewench : : Deb I agree with your advice except I do not understand the value of the P trap on a 2" indirect line. I would read if you care to explain. LonnythePlumber : Code. : Indirect waste over 5' in length shall have a p-trap installed. Indirect waste over 15' must have a p-trap and a vent. : Deb : The Pipewench Reply: The code is similar here concerning traps on indirect drain lines. The reason behind it is to prevent foul odors from indirect drain lines from entering the living space. I see this a lot in restaurants, cafes and diners. e-plumber
