Water Pressure Reducer Replacement
Posted by Larry on December 28, 2003 at 08:47:59:
My water pressure reducer has evidently failed. I get water squirting out of the relief valve of the water heater early in the morning and in the afternoons. I put a gauge on a faucet and it read 175PSI this morning at 6:00AM. This reducer has been on less than four years. The water company says we have up to 230 PSI on the public lines here. What type of reducer should I buy. Is there an industrial grade that will handle reducing from over 200 pounds down to 50 or 60? Should I put in two? If so, specifically what make and model? I have found that most of the advice I get at the building supply houses is not very dependable so I thought I would inquire here. Thanks.
