| Posted by jimbo on December 27, 2003 at 22:15:48: | |
| In response to Re: Water heater intake nipple leaking | |
:The cold water inlet has the plastic dip tube inserted in it. There is usually a foam or rubber bushing around the top of the dip tube. Make sure this assembly is seated all the way into the inlet female fitting; if not, it could interfere with your nipple threading in far enough. |
| There are none. |
