| Posted by Sylvan TiegerLMP on December 26, 2003 at 16:45:56: | |
| In response to Re: central heating hammer | |
: how can i eradicate what is probably a contraction/expansion noise.It's audible when central heating boiler is ACTIVE & when it deactivates.It appears to eminate from a single point.I'm reluctant to remove flooring.It would be a major task. I would appreciate any practical cost conscious advice. If you hear a "rubbing" sound you maybe headed for a premature heating system failure as this rubbing which causes friction can and does wear out the thin walls of most modern heating materials. You may want to contact a LMP to see if adequate provisions were provided for the coefficient of expansion and contraction of these heating lines. For copper systems the velocity should not exceed 3 FPS especially if the heating water is 180 degrees or more as this system will fail from erosion. Hydronic systems should be felt never heard unless there is a problem in design or air in the system |
| There are none. |
